Me han confirmado las placas que me van a instalar, adjunto la ficha para que me deis vuestra opinión, en estos temas técnicos ando muy perdido.
PV-Enterprise Sweden AB
Module Type PVE-MTF1-180-5
PHYSICAL CHARACTERISTICS
Distance between module installation points :
Length .................................................. 1625 mm
Width............................................. ........840 mm
Physical dimensions :
Length............................................ .......1637 mm
Width............................................. ........855 mm
Thickness......................................... .....35 mm
Weight............................................ .......17 kg
Number of cells in series.........................72
Number of cells in parallel.......................1
Distance between cells...........................2 mm
Distance between cells and glass edge
Sides:............................................ ........15 mm
Top:.............................................. .........17 mm
Bottom:........................................... .......17 mm
ELECTRICAL CHARACTERISTICS (1000 W/m2, 25 ºC cell, AM 1.5)
Maximum power (Pmax)..........................180 Wp +3%/-3%
Maximum power voltage (Vmax)..............36,00 V
Maximum power current (Imax)................5,00 A
Open circuit voltage (Voc).......................43,80 V
Short circuit current (Isc).........................5,47 A
Maximum system voltage........................850 V
NOCT (800 W/m2, 20 ºC, AM 1.5, 1m/s) 46ºC
Temperature coefficients.........................NOCT 46°C, TC Im 0,04%/°C, TC Vm – 0,38%/°C,TC Pm – 0,47%/°C
CONSTRUCTIVE CHARACTERISTICS
Cells............................................. .........Mono crystalline 125X125 mm
Contacts.......................................... ......Full length soldered
Laminate.......................................... ......EVA
Front face.............................................. .Anti-reflective structured tempered glass
Back face.............................................. .Multi layer foil
Frame............................................. .......Anodized aluminium 3,5 cm high
Junction boxes.......................................Filled up permanently
Cables and Connectors..........................2 x 85cm 4mm2 Huber & Suhner (new) cables and connectors
