Basic 18kw pellet feed setting
Hi, I own an Basic 18kw boiler by 3 mounts. The consumption of this until now at an outside temperature of 3 degrees, house of 140 m2 ,20 degrees indoor , temperature wireless termostate and 10 cm insulation of house is about 15kg per day.
The boiler is now in eco mode and pellet feed on auto. If I want the change the feed mod from auto it don’t let me. Someone has any way to modify this or how I can adjust manually the amount of pellets ?
VIVA EL GOOGLE TRANSLATE. [emoji23][emoji23][emoji23][emoji23][emoji23][emoji23]
Traducción literal del castellano. A ver dónde llega esto.
http://www.coalcerenovables.com
Pasión por la biomasa.
