how can i change my password on the forum? it remembers it when i login cos i told it to, but if i try and login on my laptop it says password failed so how can i change it please?
You have to go to "Perfil" and there you can change it. The problem is that you have to know your actual password to change it and have a new one. If you know it, you just have to write it in "Contraseña actual". After that you enter your new password in "Nueva contraseña" and in "Confirmar contraseña". It should work.
If it doesn't, try to write to the webmaster or probably if he reads this he will write you.
Good luck!
